I have a similar question. I have a label that uses the same field on two lines but not using the coded value both times. For example how do I get the following result.
[basenameid] & vbnewline & [basenameid]
Should look like this when verified. And it does
N65432
N65432
What i want is the same code altered to say
N65432
Naval Station Glouse
basically i am using the same field but with its coded and uncoded values. So far i can't get the above script to work. what do i need to add or change in order to get the result i am looking for?
