Label Expression to Display Code from Coded Value Domain
10683
6
10-05-2011 08:23 AM
TylerKiehle
So, I've got a [MATERIAL] field that has a coded value domain associated with it in the geodatabase.  The domain is like:
Code    Description
CI           Cast Iron
AC          Asbestos Cement
How can I get the code value to use in my label expression?
PrasadRao1
Uncheck "Display Coded Value Description"
http://forums.esri.com/Thread.asp?c=158&f=1696&t=296653
RichardLafleur
I have a similar question. I have a label that uses the same field on two lines but not using the coded value both times. For example how do I get the following result.
[basenameid] & vbnewline & [basenameid]
Should look like this when verified. And it does
N65432
N65432
What i want is the same code altered to say
N65432
Naval Station Glouse
basically i am using the same field but with its coded and uncoded values. So far i can't get the above script to work. what do i need to add or change in order to get the result i am looking for?
AndrewZimba
Unfortunately that only seems to work in attribute tables, not in labels.
TonyDaSilva1
Maria_TeresaAto_Vertiz1
This action resolved the problem.
DavidForbuss1
Yes, that worked thank you!
