I'm using Portal 10.6.1 and It works ok but I want to change number format:
Now I see numbers like that (incorrect):
1.205.302,20
This format is european but I configured my Portal for MX and Spanish, so I don't understand why is showing this number format
I want this format(correct):
1,205,302.20
Webmaps(identify), Dashboard(all numbers), WebmapApps(all widgets), all of them shows numbers using this incorrect format, usage of Portal(see the image) is showing the same incorrect format, so I think it's a global parameter.
I tried with Culture, Region and Language parameters in Portal but It doesn't work, I see number in the same incorrect format.
My IIS and Operating System are configured in correct number format(Region and language)
Where can I modify Portal parameters or directly change the javascript function that formats numbers to see different( in the correct format)?
I would appreciate your help.
Thanks.
