What is the URL I use to share a map created in ArcMap to mycontent on the ArcGis Portal?
966
01-12-2017 04:53 AM
Zachary_Rambo
Trying to share a service on ArcMap for Desktop to the GIS Portal on ESRI online. Need the server URL
PaulDavidson1
Zachary:
I'm not quite clear what you have and what you're trying to get to.
Can you clarify?
Do you have an mxd, a map service on an ArcGIS Server or ?
This might get you pointed in the right direction:
My Content supported items
DerekLaw
Esri Esteemed Contributor
Hi Zachary,
If you're trying to register a map from ArcMap (e.g., a .mxd document) with your ArcGIS Online organization, it won't work. That is not a supported workflow. You need to publish your map document as a map service first, then it can work within ArcGIS Online. You can publish directly to ArcGIS Online and create a hosted feature service, or publish to an ArcGIS Server site (which you would have in your organization).
FYI, How to publish a service from ArcMap or ArcCatalog—Documentation | ArcGIS Enterprise
As Paul said, if you could please clarify what you want to do, then we can help further.
Hope this helps,
