WebGIS DR restore creating PostgreSQL with each restore
2489
10-13-2022 01:09 PM
by Anonymous User
Not applicable
We are operating an on-prem, federated, 10.9.1 Portal with a 'primary' and 'secondary' environments.  We use WebGIS DR to create a backup of the primary, and use it to restore the secondary (daily).  (When necessary we fail over from the primary to the secondary when required via Netscaler and Host file changes.)
The colleague who initially setup our WebGIS DR configuration left.  We have noticed that each restore to our secondary creates a PostgreSQL db folder in the Portal server install root on the secondary (which in our case is D:\arcgisportal\.  I cannot find where this is configured anywhere in the webgisdr.properties (which is stored in D:\propfiles in our environment).  Is there a WebGIS DR default setting that specifies the root \arcgisportal\ directory?  More importantly, can we simply delete all of these old PostgreSQL directories?  They're only a few hundred mb each, but are a bit of a nuisance.  Thanks
Justin
Tags (1)
JonathanQuinn
Esri Notable Contributor
You can delete them manually for now; at 11.0 they're cleaned up automatically after the restore completes.
JonathanQuinn
by Anonymous User
Not applicable
Thanks Jonathan, good to know.
Somewhat related, and I think I found the answer in another thread several years old, but in the same root \arcgisportal\ diretory is an 'upgrade-backup' folder.  That's safe to delete as well, correct?  (Our upgrade from 10.8.1 to 10.9.1 was completed back in March 2022)
Thanks again
JonathanQuinn
Yes, if you're confident you won't need your 10.8.1 data anymore, you can delete it.
by Anonymous User
Not applicable
They're actually triggering returns in our organization's vulnerability reports
