Web Tool: calculate geometry attribute in a Feature Layer Hosted
1343
06-15-2020 01:22 AM
SistemiTerritoriali
I created in ArcGIS Pro 2.5.1 a model that uses the "Calculate Geometry Attribute" function to calculate PointX and PointY coordinates on two Double Long/Lat fields of a point layer.
I published the model as a Web Tool on ArcGIS Enterprise 10.8 with Portal.
When I go to use this web tool in a web map with a point feature layer hosted, which I use as input dataset, I get this error:
ERROR 130051: Input feature class is not registered as versioned. Failed to execute (Calculate Geometry Attributes). Failed to execute (Modellocalcolocampo). Failed to execute (Modellocalcolocampo). Failed.
From this error it seems that it is not possible to change the values of a field of a Feature Layer Hosted using a web tool.
Is this true or am I getting something wrong?
Thanks for your assistance,
Paolo
