Web Map symbology not displaying
1643
05-29-2024 01:37 PM
wgreen90
I've recently upgraded from ArcGIS Enterprise 10.6.1 to 10.9.1. In Map Viewer Classic my Web Map symbology appears similarly to how it did in 10.6.1 with Parcel, Streets and Railroad layers combined into 1 Web Map. In the newer Map Viewer, the data symbology for this WebMap doesn't appear, however if I view each layer separately, I can see them in the newer Map Viewer. Any feedback is appreciated. Thank you!
wgreen90
Thanks @PTW ! I resolved the issue. The layer data was in the Map Viewer. I simply removed and added the layer back into it and the symbology appeared. I appreciate your help!
PTW
I would check the Visible Range for each layer under Properties in the New Map Viewer. I'm guessing it is set to a range that does not include your current map view.
In Classic Viewer click on the Symbology symbol for the layer and then Options. Then you should see the Visible Range slider.
However I could be misunderstanding your issue, if so can you provide a screenshot?
wgreen90
