Change Portal Installation Directory
791
08-28-2020 09:27 AM
CarlosKrefft
Anyone have ideas of how I can change the installation directory in portal?
I contacted support and they say it's not possible, but many times I've found solutions or workarounds to things support says are not possible. Looking for thinking outside the box.
I cannot migrate using WebGISDR tool or a High-availability setup because installation path needs to be the same in both these methods of migration.
I'm thinking there has be a registry hack, postgres find and replace or something that could be done.
Thanks!
Cheyne
Have you tried installing Portal on a new drive, then reassociated the Content Directory and Web Adaptors?
