web map layer symbol
3131
04-22-2022 02:46 AM
SigLM
Hello, I created a map on the portal of our organization.
When I add a layer to the map image layer, the symbols are displayed without problem.
However, when I add the same data to the feature layer, I notice a discrepancy of the symbols that I can not explain.
If someone has a solution to this problem, I am a taker.
jcarlson
Feature layers in a web map do not have access to all the same symbology options that a map image layer or desktop GIS does, and are somewhat limited.
Can you give some more details about how the symbology is being defined? Are there feature attributes being used to set things like the angles and distances?
- Josh Carlson
Kendall County GIS
SigLM
Yes, there are  definite feature attributes likes as angles and distances in desktop GIS.
SIG LM
SigLM
another details, whe have many type of symbols: points symbols, images symbols and shape symbols.
Do you know a way to solve this problem?
SigLM
SIG LM
