Installed Enterprise ArcGIS 10.9.1. Had validated the datastore with ArcGIS Server manager. Month later, couldn't publish to the datastore. Datastore unable to validate. Also checked Server Administrator - 'Invalid Token'. Tried unregistering and re-registering the Datastore. DescribeDatastore - the "Portal for ArcGIS URL" is empty. Also tried a test to run 'Updatelicense' - unable to generate a token.
Tried uninstalling and reinstalling the Datastore (was going to restore from backup). Same result. Checked Federation it validates okay. Thanks
I would quickly check if the ADMIN URL from Portal administrator directory page is showing up properly.
I had a similar issue that Owning URL was missing and the solution was to update the ADMIN URL from ArcGIS server administrator directory.
Regards,
Naveen
Regards,
Naveen
Naveen - Thanks you so much. That was totally it. I was searching all over the place for that. Thank you!!!!
same thing if the portal for arcgis is missing?
