Using UK Admiralty Charts
639
04-03-2014 08:06 AM
KateWalker
This is probably a problem with a really easy solution . . .!  I have a UK admiralty chart, converted to British National Grid, and I have a GB outline (also in BNG) and I cannot get the admiralty chart to lie in the correct position on the GB outline (it is currently sitting du north of Scotland at the minute!).
Any suggestions would be gratefully received!
KAte
Are you sure they are both in BNG? (Check Layer Properies > Source).
Also check Data Frame Properties > Coordinate System.
