Using FeatureSetbyName in Arcacde
6943
05-31-2019 10:49 AM
James_Armstrong
This is a question on using ARCADE within Portal for ArcGIS.  I have recently upgraded ArcServer,, Portal, and DataStore to 10.7.  This was done primarily to access the tools available such as FeatureSetbyName.
At this point, within Arcade, I am not able to access the profile, especially the popup which has the $map.  I can add the function to the script editor window, but upon test, all I get is ":Runtime Error: Identifier Not Found. $map".
I am not sure why the $map item is not found.  Any suggestions?
James
James_Armstrong
OK,  My Bad.  I figured this out.  IN order to use this function, the layer needs to come into the web map as an individual  feature layer.  using a full map services will not work.
James
James_Armstrong
James
BillHoney
New Contributor III
Really helpful - thanks !
SueJohnston
New Contributor III
James,
Does every layer you want to identify, then have to come in as a separate feature layer?
Thanks!
Sue
James_Armstrong
Sue,  I believe it does require layers to be add individually.  At least that is how I am working.  There may be another solution to this, or there could have  been a fix, but in all honesty, I have moved on to other issues and have not circled back to check.
If you do find more information on this or a better way, than please share.
Good Luck!
James
