Using Arcade to create hyperlink based on attribution
11193
11
07-01-2020 07:04 AM
higgy7
I am looking at using arcade to create a hyperlink in a popup based on attributes held within the data.
I have created an attribute expression as follows:
IIf($feature["TELEMETRY_MATCH"]=='YES', 'url'+$feature.FULLNAME+'?anotherpieceoftext', 'Currently not linked to telemetry')
I want to continue to use the A list of field attributes option, with the output of this expression:
I have successfully done this but instead of just a string i want the result when 'YES' to be a hyperlink.
Basically i want this to be a hyperlink:
Is this possible? Any help greatly appreciated.
Ciaran
Tags (3)
XanderBakker
Esri Esteemed Contributor
Hi Ciaran Higgins ,
In that case it makes sense that UrlEncode is not available for you. Do you expect to update anytime soon? Version 10.8.1 is about to be released.
higgy7
Hi Xander Bakker
Unfortunately i don't know when we will be upgrading!
