Update URL in Web Map Layer without AGO Assistant
931
10-10-2025 01:49 PM
cjms
In Portal, I have a web map with a layer that I added using the Add from URL option; it is a rest service URL from Cityworks.
I'd like to change the url without deleting / add and removing the old one since I already set up pop-ups and other properties. It seems like I can do this using the AGO Assistant, but I'm wondering how to accomplish this without the assistant?
TimoT
Hi @cjms,
Have you tried Update ArcGIS Server site references in the Webmap item's settings? There are some caveats to use this, but if you meet the requirements, it's an easy way to update the underlying service reference.
MichaelVolz
Esteemed Contributor
Timo:
Do you know when ESRI added this capability, enterprise version?
George_Thompson
Esri Notable Contributor
Looks like 11.1 was the earliest, but I would verify the help doc page for any specifics based on the version you are using:
--- George T.
