Update point coordinates?
2650
08-18-2010 02:21 PM
WilliamClark
I have an easy question:
When point data lat/long is changed during an edit session in the attribute table or a new record is created, that only changes the properties of the attribute table.  How does one get the changes or additions reflected in the mapping environment?  I've spent a lot of time labelling and querying the file as is and don't want to edit the xls., Add XY...event layer...export etc. again.
Thanks.
JohnSobetzer
Honored Contributor
I don't think in the basic install you can just press a button and have the points move.  You might export your dbf to a new one, add it back in and use the Add XY Data.
You might, depending on your work flow, add a temporary point using the Sketch tool - right click - Absolute XY, and then move your target point to it using snap, or if it is a new point attribute it after adding it,  and then when you are done delete the unattributed points and run the Add XY Coordinates tool to update the table.
WilliamClark
Yeah, that is what I thought but if there was something that made things easier I didn't want to miss it and figured I'd ask.  I have been using basically the method you describe.  Thanks.
