Unable to reference hosted scene layers in to one Web scene
175
10-02-2025 07:43 AM
NarayanHamde
Greetings, I have multiple heavy multipatch layers which I want to publish in a scene on arcgis server in on premise enterprise setup. When I publish these layers as a scene, some of the layers get published, others fail to be published. Sometimes the reason is waittimeout. I also tried to publish their scene layer package layers but same happened. Now I am publishing individual SLPKs one by one. I have to get all of the layers in to one web scene so that I can visualize all layers in one scene. Firstly, whatever I tried why it did not work and what are other ways to do this publishing? And second, how can I get these published SLPKs in to one web scene in portal?
ArchitSrivastava
Hello @NarayanHamde ,
To better understand what’s happening, could you clarify a couple of things:
  • What version of ArcGIS Enterprise are you using?
  • How large are the multipatch layers or the SLPKs you’re working with (in GB)?
  • When you say some layers fail with waittimeout, does this show up in the ArcGIS Server logs at the SEVERE or WARNING level?
It would be great, if can share the below details as well:
  • Server Logs – Set logs to DEBUG temporarily and review what happens at the moment publishing fails. This can confirm if it’s a timeout, memory, or cache issue.(Be sure to switch back to SEVERE or WARNING afterward, since keeping logs at DEBUG can quickly consume storage.)
  • Machine Resources – Large 3D publishing jobs can require a lot of CPU/RAM. Do you know how many cores and memory your ArcGIS Server site has available?
Sharing these details will really help in narrowing down the root cause of the issue.
