Unable to load ArcGIS Server backing stores
274
07-24-2025 02:07 AM
SimonSchütte_ct
MVP Regular Contributor
I have installed ArcGIS Enterprise 11.5. After federation, the Server validates successfully. For the Server URL the Webadaptor URL is used in both places, including the Admin URL (since this is a HA deployment).
However, I get "Unable to load ArcGIS Server backing stores and/or the ArcGIS Server license information"
Solved: Error: Unable to load the ArcGIS Server backing st... - Esri Community
And in Settings->about there is no information listed on Server or the Data Stores.
It looks something like this (recreated):
On the configure Server Role page I am unable to set the Server as Hosting Server, it claims Requirement "Relational Data Store is missing".
However, the Data Stores are registered successfully in the ArcGIS Server:
Certificates are imported in Portal and Server, and WebcontextURL and internal/external URLs are specified.
Any ideas on what to look for?
The only thing I can remember is: when I configured the Relational Data Store from CLI, it returned Success but also an error: could not access https://localhost:2443/datastore/.. . (this is from memory), however describedatastore returned no issues and it validates in Server Manager.
SimonSchütte_ct
I changed the Server to Hosting Server as described here: Solved: Re: Error: Unable to load the ArcGIS Server backin... - Esri Community
The About page is still empty...
This issue has nothing to do with the backing store.
