Top navigation sign-in menu bar missing in portal
9596
9
07-30-2024 01:42 PM
DanCamboia
The top navigation menu bar in portal is missing. I'm on 11.2 (fully patched) and it was working fine. Then it just stopped displaying. I've cleared the cache and tried on Chrome and Edge. When accessed from a browser on the server the navigation menu bar displays fine.
Any help appreciated.
DanCamboia
Thank you. It's working now. I had installed the patch, however, I didn't wait long enough before clearing my cache and retrying.
DavidSolari
MVP Regular Contributor
This is a known issue with the latest builds of Chrome, a deprecated feature used to display that bar was removed. There should be a hotfix patch available for your deployment.
DanCamboia
SteveCole
Honored Contributor
StephenKaranja
Thanks a lot for the link. The patch resolved the issue for me. 👍
ZachBodenner
Has anyone had this issue even after the patch was applied? I applied the patch back in July, and just this morning my navigation menu disappeared.
Happy mapping,
- Zach
ValerieHanson
Yes.  We applied the April 2024 Security patch for 10.8.1 earlier as well . . .and just last week the menu header disappeared.  We use Edge.
SaraFortnam1
I am seeing this same issue in our 10.8.1 enterprise.  The last time I logged in and was able to see the Navigation Bar was 10/18/2024.
MuradanChhay
Running into this same issue today. I believe we are on 11.3 for Enterprise
MaartendeJong
We just experienced this issue with Edge 130 and ArcGIS 11.2 with the Display patch installed. Luckily the technical article gave the workaround to re-enable MutationEventsEnabled  in newer browsers.
Edge
edge://flags/#mutation-events
Chrome (not tested, don't have chrome)
