Stacked labels with special characters and format tags
2234
06-12-2014 06:48 PM
SolBrich
I'm learning how to label with VBScript. I have to create a stacked label that contains a special character (<) and uses format tags. This is the code I'm using:
Function FindLabel ( [PCELabel1], [PCEValue1], [PCELAbel2], [PCEValue2] )
  theFirstPart = [PCELabel1] & Replace( [PCEValue1],"<","&lt;")
  theSecondPart1 = [PCELAbel2]
  theSecondPart2 = "<FNT name = 'Arial' size = '10'>" & "<BOL>" & "<ITA>" & [PCEValue2] & "</ITA>" & "</BOL>" & "</FNT>"
  FindLabel = theFirstPart & vbnewline & theSecondPart1 & theSecondPart2
End Function
When I click "Verify" in the Label Expression Dialog Box I get exactly what I'm looking for, but when hit "OK" and "Apply" in the Layer Properties Dialog Box to place the labels I get:
GS-4-2014 (23) &lt;0.37
GS-4-2014
(33) <FNT name = 'Arial' size = '10'><BOL><ITA>0
My Data source is a feature class in a file based personal geodatabase. I've attached it for reference. Can anyone please explain why this is happening, and how to fix it? Thanks,
Sol
JimCousins
I used your expression and dataset, and get this result. Seems fine. Perhaps this is a subset of the full dataset, and there is some other "illegal" characters in the attributes that is causing the formatting issue?
Regards,
Jim
SolBrich
Thanks for looking at this Jim. That's the full dataset. The only thing different is I had an SQL query set up to use the script to label features "GSPCELabels.LabelStyle" = 'PCE1 LE 0.37 PCE2 GT 0.37'. Have a good one,
Sol
