Smart editor with related fields
674
03-29-2022 05:40 AM
BjorntenBroeke
I have a Web-App with a Smart editor on addresses. In this App - used for construction works - I have two Fields, both with a data. Because there are two to note somethiung on that address.
What I want to know if it is possible to relate the fields. If one is filled the other should be blocked.
So if the First field is YES (droop down Yes/No) and the date field is filled. THEN
The second field should be blocked. And the other way arround.
Is this possible? And where should I look for a solution. Is this created in the Map or should it be setup in the Smart Editor?
- the addresses (points) are Feature layers (not hosted)
