Showing Description in Legend
2651
5
05-05-2010 03:39 PM
ZachDircksen
Hello Cartographers,
I have a legend with a detailed description I am trying to add.  I have been able to add the description, but am not able to have the text of the description for each layer wrap.  The text is one long string and makes for a very widelagend box.  Anyone that could help me wrap the text of my description in the legend, I would really appreciate the help.
Sincerely,
Zach
by Anonymous User
Not applicable
You can do this through the layer properties dialog.
Open up Layer Properties > click the Symbology tab > click the Description... button
and add your text.
The trick seems to be that you have to hold the place your cursor at the end of the text where you want it to break and then hold the control key down at the same time that you press the enter key. This should allow you to show multiple lines in the legend for you layer.
You will also have to to into your legend properties > select the Items tab > and then click the layer, Selected item(s), that you want multiple lines of text for > click the Style... button > and choose one of the option that includes "Description".
BrianKaplan
That solution needs to be modified if you are working with a choropleth map because the Description option is only available for Single Symbol.  I used the concept presented here
http://www.aubreyrhea.net/gis/index.php/tag/legend/
and used a polygon data layer (it would work with point or line too) and displayed the symbology as a Features (single symbol) and then used the Description box.  I set up the symbology to be no fill and no line.  I hope this helps someone.  BrianK
jenniferrankin
what if the layer you are trying to show is a raster? i have a couple of rasters that i need to have in the legend and i cant seem to figure out how to wrap their text.
Jen
JensKolstad
You can try the "Multiline Legend Text" extension in ArcScripts - http://arcscripts.esri.com/details.asp?dbid=12550
It is an old script - but it works in ArcView 9.3.1
Jens
GwenWolph
Has anybody written an update to this script that works in ArcGIS Desktop v. 10?  I have a polygon layer that I want to symbolize by feature, but the main title is too long, and the "description" work around won't work for the main title of the layer when you symbolize by feature.
Jens
