Restore deleted Web Map in ArcGIS Portal
1896
03-01-2024 01:38 AM
EsraCındır
Hello,
In ArcGIS Portal, where I am using version 10.9.1, I accidentally deleted the Web Map that I used in my WebApp application. Unfortunately, there is no backup of Web Map. Is there a place where the system keeps automatic backups of web maps? Or has anyone experienced such a problem before and been able to recover the web map?
RyanUthoff
MVP Regular Contributor
Unfortunately, there is no "recycle bin" functionality in Portal. Once it's deleted, it's gone.
Your best bet is to perform a WebGISDR restore of your ArcGIS Enterprise deployment, assuming you're making backups. Alternatively, doing a server level restore of the server if you have those kinds of backups.
EsraCındır
Thank you Ryan for answer and suggestions 🙂 . It is really a big missing that there is no recycle bin in portal
