Registering an AWS PostGIS database with ArcGIS Server
327
03-29-2025 09:44 PM
LIZDean
Hello, I have set up a PostGIS database base in AWS and am trying to register it to ArcGIS Server.
In ArcGIS Pro on my desktop, I can connect to the PostGIS and a .sde connection file is created in my project directory.
When I go into Server Manager and try and connect using the .sde file created locally nothing happens.
If have an S3 bucket in the same AWS instance and can register that in Server Manager so connection is not an issue.
Are there steps that I am missing or does the .sde file need to be created on the server server?
VinceAngelo
Esri Esteemed Contributor
The security models of both AWS and PostgreSQL might be interfering here, as well as the operating system. The default is "no connectivity" so you need to explicitly grant communication from the IP address of the host where ArcGIS Server is running. If in doubt, try installing a PostgreSQL client like psql on the Server box, and try connecting from that. If psql can't connect, then the networking to PG is still not correct, and it's an AWS admin task.
Note that PostGIS is the spatial extension to PostgreSQL (implementing geometry and geography types), so it's not PostGIS you connect to, but PostgreSQL itself (in this case, the PG RDS instance endpoint). The AWS admin needs to make a route from the ArcGIS Server EC2 host to the RDS endpoint. If the Server host is on-premise, you'll have a suboptimal solution (due to the high latency), but it still requires an explicit grant of access to the Server IP (you may have firewall issues from the Server node to the RDS as well).
Good luck!
- V
