Reference Table from SQL Database that is not an Enterprise Geodatabase?
2646
09-09-2024 04:49 PM
StefanCoe1
We have an MS SQL Server Database registered as a Data Store in our Portal. The database is not an Enterprise Geodatabase. When trying to publish tables/views to Portal using ArcGIS Pro,  the only option seems to be as a hosted table. Is it possible to reference the data instead of copying it (hosted)? Thanks!
Marshal
Publishing referenced stand-alone tables by themselves is possible in ArcGIS Pro 3.3+.  In previous versions of Pro, you had to publish a geometry layer alongside the table (common workflow was to add a "dummy" layer to enable publishing the referenced table).  Both of these methods work in Enterprise 11.1 or greater, but I am not sure past that.
https://pro.arcgis.com/en/pro-app/latest/get-started/whats-new-in-arcgis-pro.htm
  • You can share stand-alone tables as map image layers and map services that reference registered data without having to include data layers in the map.
JakeSkinner
Esri Esteemed Contributor
@StefanCoe1 what version of Portal and Pro are you using?  I don't believe this was an option in earlier releases, but should work at 11.1 and forward.
Marshal
StefanCoe1
Thanks- I upgraded ArcGIS Pro to 3.3 and now the option to share as a reference is available. Thank you!
MarceloMarques
@StefanCoe1 - You can use ArcGIS Pro & Query Layers to create your map document and then publish as an ArcGIS Server Service, read more in the link below.
Query layers—ArcGIS Pro | Documentation
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
