"%" Prefix and Data Connection Loss while publishing standalone table to ArcGIS Enterprise
562
03-12-2024 09:01 AM
StefanAngerer
Hi everybody,
I'm facing an issue publishing a standalone table (database table, not enterprise geodatabase table) from an Oracle SDE connection to ArcGIS Enterprise. After trying to publish, a "%" symbol appears in front of the table name, and it loses its data connection, leaving the publishing process with an error.
Does anybody know if there is something I have to consider when trying to publish database tables? Is this even possible? Or better asked: whats the best practice in this case?
Any insights or suggestions would be greatly appreciated!
Stefan
ChrisUnderwood
Hello @StefanAngerer Yes, you can publish from an Oracle Table in a non-Esri Database, to a Table (hosted) in ArcGIS Enterprise.
Please can you detail some information from your system, eg versions you are using etc. And include some notes on the workflow you are following, and a screenshot of the error message etc.
