Publishing Custom Symbology from ArcGIS Pro to Portal for ArcGIS
6772
11
09-08-2021 08:08 PM
DeanHowell1
How do I publish a custom symbology set to be able to be used in Portal for ArcGIS?
I have imported a custom system set into ArcGIS Pro and wanted to find out how to have that custom symbology set available in Portal for ArcGIS?
JeanetteHarlow1
Thank you!  That worked.
I will add that I tried all the publishing options before, and they did not work.  I suspect it did not work previously because I had symbology dependent on two variables, not just one.  Adjusting to one variable, and publishing as a map image layer worked.
TanuHoque
@JeanetteHarlow1
cool. Glad that it works. Even with two variables, it should work fine with map image layers.
