Problems with the ESRI OpenSearch end point example for GeoPortal
2566
07-22-2014 10:42 AM
LukeLambert
I'm attempting to follow the ESRI example (found here) of adding an OpenSearch end point to GeoPortal.  I believe I've followed all of the steps faithfully, but when I use GeoPortal to search only the new NSIDC source I get the message:
Unable to load /geoportal/rest/find/document?rid=nsidc&ridName=National%20Snow%20and%20Ice%20Data%20Center&rids=nsidc&searchText=water&start=1&max=10&maxSearchTimeMilliSec=10000&f=searchpageresults&dojo.preventCache=1406049254363 status:500/geoportal/rest/find/document?rid=nsidc&ridName=National%20Snow%20and%20Ice%20Data%20Center&rids=nsidc&searchText=water&start=1&max=10&maxSearchTimeMilliSec=10000&f=searchpageresults
Clicking on the link I get the same error from Tomcat:
HTTP Status 500 - Error while getting items from repository with id of nsidcCould not get record from db with rid = nsidc
type: Status report
message: Error while getting items from repository with id of nsidcCould not get record from db with rid = nsidc
description: The server encountered an internal error that prevented it from fulfilling this request.
Apache Tomcat/6.0.41
Watching the the gpt log, I see the following stack trace when I search for "water"
Jul 22, 2014 1:17:07 PM com.esri.gpt.catalog.search.SearchFilterKeyword setSearchText
FINE: search text value posted
FINE: search text value posted water
Jul 22, 2014 1:17:07 PM com.esri.gpt.catalog.search.GptRepository readHarvestRecords
INFO: DB Query SELECT PROTOCOL_TYPE, HOST_URL, PROTOCOL, TITLE, DOCUUID, ID FROM GPT_RESOURCE WHERE UPPER(TITLE)= ? AND ((APPROVALSTATUS = 'approved') OR (APPROVALSTATUS = 'reviewed')) AND SEARCHABLE = 'true'
Jul 22, 2014 1:17:07 PM com.esri.gpt.framework.sql.DatabaseReference openConnection
FINE: Connection opened for gpt, jndiName: jdbc/gpt, productName: PostgreSQL, driver: PostgreSQL Native Driver PostgreSQL 9.1 JDBC4 (build 901)
Jul 22, 2014 1:17:07 PM com.esri.gpt.control.georss.RestQueryServlet execute
SEVERE: Error executing query.
com.esri.gpt.catalog.search.SearchException: Error while getting items from repository  with id of nsidcCould not get record from db with rid = nsidc
        at com.esri.gpt.catalog.search.SearchEngineExternalCsw.init(Unknown Source)
        at com.esri.gpt.catalog.search.SearchEngineFactory.intializeEngine(Unknown Source)
        at com.esri.gpt.catalog.search.SearchEngineFactory.createSearchEngine(Unknown Source)
        at com.esri.gpt.control.georss.RestQueryServlet.executeQuery1(Unknown Source)
        at com.esri.gpt.control.georss.RestQueryServlet.execute(Unknown Source)
        at com.esri.gpt.framework.context.BaseServlet.doPost(Unknown Source)
        at com.esri.gpt.framework.context.BaseServlet.doGet(Unknown Source)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:723)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
        at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:861)
        at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:606)
        at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
        at java.lang.Thread.run(Thread.java:701)
Caused by: com.esri.gpt.catalog.search.SearchException: Could not get record from db with rid = nsidc
        at com.esri.gpt.catalog.search.GptRepository.readHarvestRecord(Unknown Source)
        ... 23 more
Jul 22, 2014 1:17:07 PM com.esri.gpt.framework.sql.DatabaseReference closeConnection
FINE: Closing connection for gpt, jndiName: jdbc/gpt
There are no other errors reported by either GPT or Tomcat.  Any help would be appreciated.
LukeLambert
The NSIDC_GetRecords_Response.xslt error was a red herring.  Once I cleared that up, everything worked as advertised.  The main takeaway is not to list a new repository after another repository that might have a (regex) matching key.
LukeLambert
One step further down the rabbit hole:
In the repository listings in gpt.xml, repositories are regex-matched by key name in the order they are listed.  Before any user additions, the last repository listed in gpt.xml has a key of '*', which will match anything.  Any other repository listed after that won't be considered.  There's no warning that a search request can match more than one key, that repository order matters, or that it's first key match rather than best key match.  See the 'getAttributes' method of SearchEngineFactory for the offending behavior.
With that hurdle overcome, I'm not getting an exception about not being able to parse the getRecordsResponse of the supplied NSIDC_GetRecords_Response.xslt.
LukeLambert
