Printing map corner coordinates only
675
01-27-2014 10:05 PM
surendarmohan
This I am sure must be simple - till I find it!
I have a map which I want to print in my report.  I need to print the coordinates of map corners only.
I tried out graticule wizard where I can define graticule intervals, but how do I get only the corner coordinates?
NidhinKarthikeyan
Honored Contributor
You can try using Make Grids And Graticules Layer (Cartography).
If it doesn't work, you can create a Point Feature Class and create feature on all four corner of the layout. Note down the extent of Point Feature Class from Layer Properties.
