Curious if others have experienced any issue when changing point data symbology in a Portal webmap (v10.3 served up internally).
I can change polygon/line symbology without any mishaps however, when I try to adjust point data symbology:
I automatically get an error:
And then I'm hooped...
I'm at a loss... what gives?
Problem solved...
Ran full Portal indexer (reindex) and that seemed to sort out the issue.
https://host.domain.ca:7443/arcgis/portaladmin/system/indexer
Good find, Douglas. Something to keep in mind for anyone else who runs into an issue where symbols, groups, users, or other items are not visible is to run a full Portal reindex. This issue may occur during an upgrade of Portal from one version to another:
Upgrade Portal for ArcGIS—Portal for ArcGIS (10.3 and 10.3.1) | ArcGIS for Server
Common problems and solutions—Portal for ArcGIS (10.3 and 10.3.1) | ArcGIS for Server
