We have a new ArcGIS Enterprise 10.8.1 stack that we have set up. Everything is licensed, there is a hosting server set, Datastore, and I've got a few users spun up. The only issue is that my Map tab is missing.
Yes...it's completely missing 😕
I've set up a few Enterprise stacks in the past but have never seen this behavior before.
Has anyone else ever experienced this?
Is this a Single-machine or multiple-machine deployment?
1. What happens when you type a similar URL in the browser https://myportal.domain.com/arcgis/home/webmap/viewer.html
2. Are all the required ports allowed through machine and network firewall?
3. Sometimes restarting your ArcGIS Enterprise Machine resolves the issue.
4. You may stop the System services (Run > services.msc) for ArcGIS Data Store, ArcGIS Server and Portal for ArcGIS. Open Task Manager to check if the services have stopped completely.
Then Start the Services in the following order.
Since the ArcGIS Server site is already federated and designated as a hosting server, I am not suggesting anything else than contacting Esri Tech Support.
Figured it out. Users with and 'Advanced' license cannot see the map.
[Update 2022-09-29]
I was able to allow my portaladmin user to see the Map tab by doing either of two things:
I still don't understand Portal licensing well enough to explain or recommend a solution with confidence, but here are a few additional things that I learned from reading the doc and testing:
If this is correct, it makes sense that the initial administrator has the Advanced user type and Administrator role - this allows them full permissions to manage the portal, without consuming any potentially costly app licenses (the Advanced role only includes the Organization Website "application" [per portal UI] or "administrative privilege" [per doc] which I don't think requires a separate paid license).
Accordingly:
There are some dependencies between user types and roles, in that you can't arbitrarily assign any role to any user type. For example, I can't assign a user the Basic user type and the Administrator role. Among the compatible user types / roles, however, the two settings seem to be independent - I can assign any allowable user type to my portaladmin user, and they can still manage the portal as long as I keep the Administrator role.
Realistically, I should probably keep portaladmin as Advanced/Administrator, and create a separate user for viewing maps. I just created this deployment for a quick test, though, and was trying to do everything as portaladmin. It wasn't as quick as I had hoped, but it did make for a good learning experience.
[Original]
"Users with and 'Advanced' license cannot see the map."
I'm observing the same thing on my new, stock, empty ArcGIS Enterprise 10.8.1 base deployment. My initial administrator (portaladmin) was set to the Advanced user type, and cannot use the WebMap Viewer app; I'm not sure whether I set the user type explicitly, or if that's the default. If I switch it to Creator, for example, the Map tab appears.
The Portal UI states that that the Advanced user type is: "Compatible with all roles and licenses"
If I'm reading the doc correctly, it doesn't discuss this Advanced user type. I'd like to make an informed decision about whether to change this user's type and, if so, to which other type. I'd appreciate any guidance or references to relevant doc. Thanks!
