Portal items- number of views
7911
13
05-02-2018 09:47 PM
JosephJose
Somewhere in conversation, I came across a json url which gives me the number of views on the particular item be it a webmap, app, kml.
Have lost it .Can someone point me out correctly?
Is it something that only an admin can do?
hoogw
I found a bug/error in ESRI REST API, please fix the bug in code or update doc either way:
https://developers.arcgis.com/rest/users-groups-and-items/item.htm
the api reads:
https://<content-url>/items/<itemId>
also give example at bottom
https://www.arcgis.com/sharing/rest/content/items/10ba62fe50864339a8a3e0f18ca85506
You actually will NOT get any info by use above link format. Only a blank page
You must add
?f=json
by define format to get something
This is a working example:
https://www.arcgis.com/sharing/rest/content/items/a22e7905d67f4330bbec630eebd38419?f=json
esri staff, please fix the rest api code, by define 'f=json' format by default.
or update the rest api doc above, by put a NOTE: * remind user must append ?f=json at the url end
PatrickMcKinney99
Adding f?=psjon will return an easier to read version.  But if run within a script, I guess that doesn't matter as much.
Borch
Dear all,
Is there any workflow to reset the numviews property without connecting to the portal postgres database?
I cannot find the way to update the property in sharing/rest.
Best
Borja
ToddW_stl
Yes!  I posted a solution on another reply in this thread.
