Portal for ArcGIS license deactivation
956
06-07-2024 01:33 AM
tadaskiškėnas
hello.
we testing arcgis enterprise and installed Portal for ArcGIS license.
if we like use this license on product environment, should i deactivate this license somehow or we can simply copy license file and use it on new installation?
sry for my english.
simoxu
by MVP Regular Contributor
Depending on what license you have. if it's a production license you can use for your production, if it's some sort of trial license, you should not use for production.
To deactivate a license, you can create a new license to replace the old one in My Esri.
If you are not sure, the best way to find out is to contact your local Esri distributor.
simoxu
tadaskiškėnas
merci.
