Portal for ArcGIS 10.4.1 to 10.5.1 fail
3476
11
10-16-2017 06:18 AM
Luiz_AmadeuCoutinho
I´m trying to upgrade my server to 10.5.1 and I´m following the steps on url . Everytime I´m getting an error on Step 8
"Choose to Continue Portal Upgrade. .....Specify the user name, password, email, and identity question and answer of the initial administrator account. ...."
or sometimes
Here I´m running a federate/hosted server + Portal and Datastore on Linux (single machine).
I ran portaldiag to check and here the result.
Portal for ArcGIS 10.5.1 Diagnostic Tool
               Hostname: smart.....oa.pt
 DIAG000: Check for installation as root                       [PASSED]
 DIAG001: Check for 64-bit architecture                        [PASSED]
 DIAG002: Check OS version                                     [PASSED]
 DIAG003: Check hostname for invalid characters                [PASSED]
 DIAG005: Check system limits                                  [PASSED]
 DIAG004: Check installed packages                             [PASSED]
 DIAG016: Check Portal for ArcGIS ports                        [PASSED]
 DIAG024: Check localhost resolution                           [PASSED]
 DIAG029: Check file system type                               [PASSED]
 DIAG020: Check hostname IP address mismatches                 [PASSED]
 DIAG026: Check processes of Portal for ArcGIS core services   [PASSED]
 DIAG028: Check data directory                                 [PASSED]
There were 0 failure(s) and 0 warning(s) found:
Portal Log:
<Msg time="2017-10-16T12:26:22,906" type="SEVERE" code="209024" source="Portal Admin" process="27847" thread="12" methodName="" machine="smart.....oa.pt" user="" elapsed="">The process of creating a new site failed. Reverting site creation. Migration failed. Index Service configuration failed.</Msg>
<Msg time="2017-10-16T12:27:26,38" type="VERBOSE" code="217063" source="Portal" process="27764" thread="1" methodName="" machine="smart.....oa.pt" user="" elapsed="">The process monitor did not find the connection to the configuration store. The site may not have been initialized. After the site is initialized, the check for database processes will be reattempted.</Msg>
Database log:
LOG:  database system was shut down at 2017-10-16 04:25:49 PDT
LOG:  connection received: host=xxxx port=58282
LOG:  connection authorized: user=xx database=xx
LOG:  disconnection: session time: 0:00:00.010 user=xx database=xx host=xxx port=5xxx
LOG:  received fast shutdown request
LOG:  aborting any active transactions
FATAL:  terminating connection due to administrator command
LOG:  disconnection: session time: 0:00:00.314 user=xx database=xx host=xx port=5xxx
LOG:  autovacuum launcher shutting down
LOG:  shutting down
LOG:  database system is shut down
AmalHorchi
Thanks luiz , you mean that i must install AEB 10.6 ? can you explain me more .
AmalHorchi
This is my log file
<Msg time="2018-05-24T15:48:38,877" type="INFO" code="217039" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Service de journalisation démarré.</Msg>
<Msg time="2018-05-24T15:48:38,885" type="VERBOSE" code="218020" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Get the machine name from the portal-config.properties file: null.</Msg>
<Msg time="2018-05-24T15:48:38,885" type="VERBOSE" code="218021" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Get the fully qualified name for the local host: null.</Msg>
<Msg time="2018-05-24T15:48:38,885" type="INFO" code="218019" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">The machine name has been changed. The machine name in the portal-config.properties file is null. The fully qualified name for the local host is DATA.APAL.LOCAL. A new self-signed certificate has been created.</Msg>
<Msg time="2018-05-24T15:48:44,276" type="INFO" code="217036" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création d’un certificat SAML en sortie .</Msg>
<Msg time="2018-05-24T15:48:44,280" type="INFO" code="217031" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Configuration et initialisation des répertoires de données, de contenu et dindex.</Msg>
<Msg time="2018-05-24T15:48:44,362" type="INFO" code="209092" source="Portal Admin" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Décompression du contenu du portail.</Msg>
<Msg time="2018-05-24T15:48:44,759" type="INFO" code="217032" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Remplacement des URL de base dans les fichiers de configuration.</Msg>
<Msg time="2018-05-24T15:48:44,781" type="INFO" code="217009" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">httpUrl : DATA.APAL.LOCAL:7080.</Msg>
<Msg time="2018-05-24T15:48:44,781" type="INFO" code="217010" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">httpsUrl : DATA.APAL.LOCAL:7443.</Msg>
<Msg time="2018-05-24T15:48:44,781" type="INFO" code="217011" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">baseUrl : DATA.APAL.LOCAL:7080/arcgis.</Msg>
<Msg time="2018-05-24T15:48:44,781" type="INFO" code="217012" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">sbaseUrl : DATA.APAL.LOCAL:7443/arcgis.</Msg>
<Msg time="2018-05-24T15:48:45,657" type="WARNING" code="217014" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Erreur de l’outil de mise à jour de l’URL. C:\Program Files\ArcGIS\Portal\apps\GeoList\index.html</Msg>
<Msg time="2018-05-24T15:48:47,565" type="INFO" code="217033" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Configuration des ports du serveur Web.</Msg>
<Msg time="2018-05-24T15:48:47,615" type="INFO" code="217015" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Type de magasin d’identifiants trouvé.</Msg>
<Msg time="2018-05-24T15:48:47,628" type="INFO" code="217034" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Configuration des propriétés du proxy</Msg>
<Msg time="2018-05-24T15:48:47,630" type="INFO" code="217035" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Configuration des informations d'identification du service d'index.</Msg>
<Msg time="2018-05-24T15:48:47,630" type="INFO" code="217002" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Configuration du portail mise à jour.</Msg>
<Msg time="2018-05-24T15:48:47,639" type="INFO" code="217046" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Démarrage du moniteur de traitement.</Msg>
<Msg time="2018-05-24T15:48:47,639" type="VERBOSE" code="217063" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Le moniteur de traitement n’a pas trouvé la connexion avec le magasin de configuration. Le site n’est peut-être pas initialisé. Une fois le site initialisé, la vérification des traitements de la base de données sera tentée à nouveau.</Msg>
<Msg time="2018-05-24T15:48:47,641" type="INFO" code="217055" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Démarrage de l’exécution du thread du chien de garde.</Msg>
<Msg time="2018-05-24T15:48:47,642" type="VERBOSE" code="217063" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Le moniteur de traitement n’a pas trouvé la connexion avec le magasin de configuration. Le site n’est peut-être pas initialisé. Une fois le site initialisé, la vérification des traitements de la base de données sera tentée à nouveau.</Msg>
<Msg time="2018-05-24T15:48:47,648" type="INFO" code="217074" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Le portail a démarré correctement.</Msg>
<Msg time="2018-05-24T15:48:47,662" type="INFO" code="217044" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Outil de limitation des journaux : début de la suppression des journaux plus anciens que 90 jours dans le chemin C:\arcgis\arcgisportal\logs\DATA.APAL.LOCAL\portal.</Msg>
<Msg time="2018-05-24T15:48:47,666" type="INFO" code="217045" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Outil de limitation des journaux : fin de la suppression des journaux plus anciens que 90 jours dans le chemin C:\arcgis\arcgisportal\logs\DATA.APAL.LOCAL\portal.</Msg>
<Msg time="2018-05-24T15:48:49,675" type="WARNING" code="217064" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Le serveur Web a été arrêté. Redémarrage du serveur en cours.</Msg>
<Msg time="2018-05-24T15:48:49,676" type="INFO" code="217053" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Démarrage du serveur Web.</Msg>
<Msg time="2018-05-24T15:49:55,455" type="INFO" code="217054" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Serveur Web démarré.</Msg>
<Msg time="2018-05-24T17:11:46,595" type="INFO" code="207037" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Niveau de consignation mis à jour en 'VERBOSE'.</Msg>
<Msg time="2018-05-24T17:11:46,803" type="INFO" code="205013" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Paramètres des journaux mis à jour. [Logs directory = 'C:\arcgis\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2018-05-24T17:11:46,803" type="VERBOSE" code="209001" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Définition du niveau de consignation sur COMMENTAIRES avant la création du nouveau site.</Msg>
<Msg time="2018-05-24T17:11:46,803" type="INFO" code="209002" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création dun nouveau site.</Msg>
<Msg time="2018-05-24T17:11:47,100" type="INFO" code="209003" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Il sagit dune nouvelle installation.</Msg>
<Msg time="2018-05-24T17:11:47,100" type="INFO" code="209089" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">La version de Portal for ArcGIS est 10.5.1.</Msg>
<Msg time="2018-05-24T17:11:47,100" type="INFO" code="209090" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Début de l’initialisation du module de contenu.</Msg>
<Msg time="2018-05-24T17:12:37,651" type="INFO" code="209091" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Initialisation du module de contenu terminée.</Msg>
<Msg time="2018-05-24T17:12:37,651" type="INFO" code="209004" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Début de linitialisation du module DB.</Msg>
<Msg time="2018-05-24T17:12:37,657" type="INFO" code="209067" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Initialisation de la base de données.</Msg>
<Msg time="2018-05-24T17:13:14,128" type="INFO" code="209068" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Démarrage du serveur de base de données.</Msg>
<Msg time="2018-05-24T17:13:19,857" type="INFO" code="209069" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création de la base de données.</Msg>
<Msg time="2018-05-24T17:13:20,105" type="INFO" code="209070" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création du compte administrateur de base de données.</Msg>
<Msg time="2018-05-24T17:13:20,280" type="SEVERE" code="209024" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Le processus de création dun nouveau site a échoué. Inversion de la création du site. {0}</Msg>
<Msg time="2018-05-24T17:20:25,24" type="INFO" code="207037" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Niveau de consignation mis à jour en 'VERBOSE'.</Msg>
<Msg time="2018-05-24T17:20:25,103" type="INFO" code="205013" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Paramètres des journaux mis à jour. [Logs directory = 'C:\arcgis\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2018-05-24T17:20:25,103" type="VERBOSE" code="209001" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Définition du niveau de consignation sur COMMENTAIRES avant la création du nouveau site.</Msg>
<Msg time="2018-05-24T17:20:25,103" type="INFO" code="209002" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création dun nouveau site.</Msg>
<Msg time="2018-05-24T17:20:25,685" type="INFO" code="207037" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Niveau de consignation mis à jour en 'VERBOSE'.</Msg>
<Msg time="2018-05-24T17:20:25,711" type="INFO" code="205013" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Paramètres des journaux mis à jour. [Logs directory = 'C:\arcgis\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2018-05-24T17:20:25,727" type="INFO" code="209075" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création dune sauvegarde des dossiers de base de données, de contenu et dindex. Lopération ne prend que quelques minutes.</Msg>
<Msg time="2018-05-24T17:25:36,124" type="INFO" code="209076" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Sauvegarde terminée des dossiers de base de données, de contenu et dindex.</Msg>
<Msg time="2018-05-24T17:25:36,124" type="INFO" code="209038" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Début du processus de migration de 10.2 vers 10.5.1.</Msg>
<Msg time="2018-05-24T17:25:36,125" type="INFO" code="209063" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Mise à niveau de la base de données de 9.2.4 vers 9.3.12.</Msg>
<Msg time="2018-05-24T17:25:36,125" type="INFO" code="209039" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Démarrage de la base de données 9.2.4.</Msg>
<Msg time="2018-05-24T17:30:36,911" type="SEVERE" code="209044" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Echec de la migration. Failed to start the database server. The startup timed out. Please check the log file at C:\arcgis\arcgisportal\logs\\database\pgsql.log.</Msg>
<Msg time="2018-05-24T17:30:47,558" type="SEVERE" code="209024" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Le processus de création dun nouveau site a échoué. Inversion de la création du site. {0}</Msg>
<Msg time="2018-05-24T17:44:30,100" type="INFO" code="207037" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Niveau de consignation mis à jour en 'VERBOSE'.</Msg>
<Msg time="2018-05-24T17:44:36,2" type="INFO" code="205013" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Paramètres des journaux mis à jour. [Logs directory = 'C:\arcgis\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2018-05-24T17:44:36,2" type="VERBOSE" code="209001" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Définition du niveau de consignation sur COMMENTAIRES avant la création du nouveau site.</Msg>
<Msg time="2018-05-24T17:44:36,2" type="INFO" code="209002" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création dun nouveau site.</Msg>
<Msg time="2018-05-24T17:44:36,306" type="INFO" code="207037" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Niveau de consignation mis à jour en 'VERBOSE'.</Msg>
<Msg time="2018-05-24T17:44:36,330" type="INFO" code="205013" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Paramètres des journaux mis à jour. [Logs directory = 'C:\arcgis\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2018-05-24T17:44:36,331" type="INFO" code="209075" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création dune sauvegarde des dossiers de base de données, de contenu et dindex. Lopération ne prend que quelques minutes.</Msg>
<Msg time="2018-05-24T17:44:36,333" type="INFO" code="209076" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Sauvegarde terminée des dossiers de base de données, de contenu et dindex.</Msg>
<Msg time="2018-05-24T17:44:36,333" type="INFO" code="209038" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Début du processus de migration de 10.2 vers 10.5.1.</Msg>
<Msg time="2018-05-24T17:44:36,333" type="INFO" code="209063" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Mise à niveau de la base de données de 9.2.4 vers 9.3.12.</Msg>
<Msg time="2018-05-24T17:44:36,333" type="INFO" code="209039" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Démarrage de la base de données 9.2.4.</Msg>
<Msg time="2018-05-24T17:49:36,570" type="SEVERE" code="209044" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Echec de la migration. Failed to start the database server. The startup timed out. Please check the log file at C:\arcgis\arcgisportal\logs\\database\pgsql.log.</Msg>
<Msg time="2018-05-24T17:49:45,605" type="SEVERE" code="209024" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Le processus de création dun nouveau site a échoué. Inversion de la création du site. {0}</Msg>
<Msg time="2018-05-24T17:51:56,902" type="INFO" code="207037" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Niveau de consignation mis à jour en 'VERBOSE'.</Msg>
<Msg time="2018-05-24T17:51:56,973" type="INFO" code="205013" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Paramètres des journaux mis à jour. [Logs directory = 'C:\arcgis\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2018-05-24T17:51:56,973" type="VERBOSE" code="209001" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Définition du niveau de consignation sur COMMENTAIRES avant la création du nouveau site.</Msg>
<Msg time="2018-05-24T17:51:56,973" type="INFO" code="209002" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création dun nouveau site.</Msg>
<Msg time="2018-05-24T17:51:57,269" type="INFO" code="207037" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Niveau de consignation mis à jour en 'VERBOSE'.</Msg>
<Msg time="2018-05-24T17:51:57,292" type="INFO" code="205013" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Paramètres des journaux mis à jour. [Logs directory = 'C:\arcgis\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2018-05-24T17:51:57,293" type="INFO" code="209075" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création dune sauvegarde des dossiers de base de données, de contenu et dindex. Lopération ne prend que quelques minutes.</Msg>
<Msg time="2018-05-24T17:51:57,294" type="INFO" code="209076" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Sauvegarde terminée des dossiers de base de données, de contenu et dindex.</Msg>
<Msg time="2018-05-24T17:51:57,294" type="INFO" code="209038" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Début du processus de migration de 10.2 vers 10.5.1.</Msg>
<Msg time="2018-05-24T17:51:57,294" type="INFO" code="209063" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Mise à niveau de la base de données de 9.2.4 vers 9.3.12.</Msg>
<Msg time="2018-05-24T17:51:57,294" type="INFO" code="209039" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Démarrage de la base de données 9.2.4.</Msg>
<Msg time="2018-05-24T17:56:57,703" type="SEVERE" code="209044" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Echec de la migration. Failed to start the database server. The startup timed out. Please check the log file at C:\arcgis\arcgisportal\logs\\database\pgsql.log.</Msg>
<Msg time="2018-05-24T17:57:04,505" type="SEVERE" code="209024" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Le processus de création dun nouveau site a échoué. Inversion de la création du site. {0}</Msg>
<Msg time="2018-05-24T17:57:54,387" type="INFO" code="207037" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Niveau de consignation mis à jour en 'VERBOSE'.</Msg>
<Msg time="2018-05-24T17:57:54,475" type="INFO" code="205013" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Paramètres des journaux mis à jour. [Logs directory = 'C:\arcgis\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2018-05-24T17:57:54,475" type="VERBOSE" code="209001" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Définition du niveau de consignation sur COMMENTAIRES avant la création du nouveau site.</Msg>
<Msg time="2018-05-24T17:57:54,475" type="INFO" code="209002" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création dun nouveau site.</Msg>
<Msg time="2018-05-24T17:57:54,762" type="INFO" code="207037" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Niveau de consignation mis à jour en 'VERBOSE'.</Msg>
<Msg time="2018-05-24T17:57:54,789" type="INFO" code="205013" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Paramètres des journaux mis à jour. [Logs directory = 'C:\arcgis\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2018-05-24T17:57:54,789" type="INFO" code="209075" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création dune sauvegarde des dossiers de base de données, de contenu et dindex. Lopération ne prend que quelques minutes.</Msg>
<Msg time="2018-05-24T17:57:54,791" type="INFO" code="209076" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Sauvegarde terminée des dossiers de base de données, de contenu et dindex.</Msg>
<Msg time="2018-05-24T17:57:54,791" type="INFO" code="209038" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Début du processus de migration de 10.2 vers 10.5.1.</Msg>
<Msg time="2018-05-24T17:57:54,791" type="INFO" code="209063" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Mise à niveau de la base de données de 9.2.4 vers 9.3.12.</Msg>
<Msg time="2018-05-24T17:57:54,791" type="INFO" code="209039" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Démarrage de la base de données 9.2.4.</Msg>
<Msg time="2018-05-24T18:02:55,449" type="SEVERE" code="209044" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Echec de la migration. Failed to start the database server. The startup timed out. Please check the log file at C:\arcgis\arcgisportal\logs\\database\pgsql.log.</Msg>
<Msg time="2018-05-24T18:03:02,312" type="SEVERE" code="209024" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Le processus de création dun nouveau site a échoué. Inversion de la création du site. {0}</Msg>
<Msg time="2018-05-24T18:08:00,822" type="INFO" code="207037" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Niveau de consignation mis à jour en 'VERBOSE'.</Msg>
<Msg time="2018-05-24T18:08:00,849" type="INFO" code="205013" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Paramètres des journaux mis à jour. [Logs directory = 'C:\arcgis\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2018-05-24T18:08:00,849" type="VERBOSE" code="209001" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Définition du niveau de consignation sur COMMENTAIRES avant la création du nouveau site.</Msg>
<Msg time="2018-05-24T18:08:00,849" type="INFO" code="209002" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création dun nouveau site.</Msg>
<Msg time="2018-05-24T18:08:01,161" type="INFO" code="207037" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Niveau de consignation mis à jour en 'VERBOSE'.</Msg>
<Msg time="2018-05-24T18:08:01,184" type="INFO" code="205013" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Paramètres des journaux mis à jour. [Logs directory = 'C:\arcgis\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2018-05-24T18:08:01,184" type="INFO" code="209075" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création dune sauvegarde des dossiers de base de données, de contenu et dindex. Lopération ne prend que quelques minutes.</Msg>
<Msg time="2018-05-24T18:08:01,186" type="INFO" code="209076" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Sauvegarde terminée des dossiers de base de données, de contenu et dindex.</Msg>
<Msg time="2018-05-24T18:08:01,186" type="INFO" code="209038" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Début du processus de migration de 10.2 vers 10.5.1.</Msg>
<Msg time="2018-05-24T18:08:01,186" type="INFO" code="209063" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Mise à niveau de la base de données de 9.2.4 vers 9.3.12.</Msg>
<Msg time="2018-05-24T18:08:01,186" type="INFO" code="209039" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Démarrage de la base de données 9.2.4.</Msg>
<Msg time="2018-05-24T18:13:01,540" type="SEVERE" code="209044" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Echec de la migration. Failed to start the database server. The startup timed out. Please check the log file at C:\arcgis\arcgisportal\logs\\database\pgsql.log.</Msg>
<Msg time="2018-05-24T18:13:08,420" type="SEVERE" code="209024" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Le processus de création dun nouveau site a échoué. Inversion de la création du site. {0}</Msg>
<Msg time="2018-05-24T20:25:46,581" type="INFO" code="207037" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Niveau de consignation mis à jour en 'VERBOSE'.</Msg>
<Msg time="2018-05-24T20:25:46,682" type="INFO" code="205013" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Paramètres des journaux mis à jour. [Logs directory = 'C:\arcgis\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2018-05-24T20:25:46,682" type="VERBOSE" code="209001" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Définition du niveau de consignation sur COMMENTAIRES avant la création du nouveau site.</Msg>
<Msg time="2018-05-24T20:25:46,682" type="INFO" code="209002" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création dun nouveau site.</Msg>
<Msg time="2018-05-24T20:25:46,986" type="INFO" code="207037" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Niveau de consignation mis à jour en 'VERBOSE'.</Msg>
<Msg time="2018-05-24T20:25:47,12" type="INFO" code="205013" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Paramètres des journaux mis à jour. [Logs directory = 'C:\arcgis\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2018-05-24T20:25:47,13" type="INFO" code="209075" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création dune sauvegarde des dossiers de base de données, de contenu et dindex. Lopération ne prend que quelques minutes.</Msg>
<Msg time="2018-05-24T20:25:47,14" type="INFO" code="209076" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Sauvegarde terminée des dossiers de base de données, de contenu et dindex.</Msg>
<Msg time="2018-05-24T20:25:47,14" type="INFO" code="209038" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Début du processus de migration de 10.2 vers 10.5.1.</Msg>
<Msg time="2018-05-24T20:25:47,14" type="INFO" code="209063" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Mise à niveau de la base de données de 9.2.4 vers 9.3.12.</Msg>
<Msg time="2018-05-24T20:25:47,15" type="INFO" code="209039" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Démarrage de la base de données 9.2.4.</Msg>
<Msg time="2018-05-24T20:30:47,174" type="SEVERE" code="209044" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Echec de la migration. Failed to start the database server. The startup timed out. Please check the log file at C:\arcgis\arcgisportal\logs\\database\pgsql.log.</Msg>
<Msg time="2018-05-24T20:30:54,276" type="SEVERE" code="209024" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Le processus de création dun nouveau site a échoué. Inversion de la création du site. {0}</Msg>
<Msg time="2018-05-24T20:31:27,352" type="INFO" code="207037" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Niveau de consignation mis à jour en 'VERBOSE'.</Msg>
<Msg time="2018-05-24T20:31:27,454" type="INFO" code="205013" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Paramètres des journaux mis à jour. [Logs directory = 'C:\arcgis\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2018-05-24T20:31:27,454" type="VERBOSE" code="209001" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Définition du niveau de consignation sur COMMENTAIRES avant la création du nouveau site.</Msg>
<Msg time="2018-05-24T20:31:27,454" type="INFO" code="209002" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création dun nouveau site.</Msg>
<Msg time="2018-05-24T20:31:27,773" type="INFO" code="207037" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Niveau de consignation mis à jour en 'VERBOSE'.</Msg>
<Msg time="2018-05-24T20:31:27,797" type="INFO" code="205013" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Paramètres des journaux mis à jour. [Logs directory = 'C:\arcgis\arcgisportal\logs\', Log level = VERBOSE, Max age in days = 90]</Msg>
<Msg time="2018-05-24T20:31:27,797" type="INFO" code="209075" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Création dune sauvegarde des dossiers de base de données, de contenu et dindex. Lopération ne prend que quelques minutes.</Msg>
<Msg time="2018-05-24T20:31:27,798" type="INFO" code="209076" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Sauvegarde terminée des dossiers de base de données, de contenu et dindex.</Msg>
<Msg time="2018-05-24T20:31:27,799" type="INFO" code="209038" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Début du processus de migration de 10.2 vers 10.5.1.</Msg>
<Msg time="2018-05-24T20:31:27,799" type="INFO" code="209063" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Mise à niveau de la base de données de 9.2.4 vers 9.3.12.</Msg>
<Msg time="2018-05-24T20:31:27,799" type="INFO" code="209039" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Démarrage de la base de données 9.2.4.</Msg>
<Msg time="2018-05-24T20:36:28,176" type="SEVERE" code="209044" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Echec de la migration. Failed to start the database server. The startup timed out. Please check the log file at C:\arcgis\arcgisportal\logs\\database\pgsql.log.</Msg>
<Msg time="2018-05-24T20:36:34,926" type="SEVERE" code="209024" source="Portal Admin" process="3264" thread="23" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Le processus de création dun nouveau site a échoué. Inversion de la création du site. {0}</Msg>
<Msg time="2018-05-24T20:53:48,479" type="INFO" code="217078" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Arrêt de lagent de nœud.</Msg>
<Msg time="2018-05-24T20:53:48,487" type="INFO" code="217004" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Sauvegarde du fichier de configuration du portail de C:\Program Files\ArcGIS\Portal\framework\etc\portal-config.properties vers C:/arcgis/arcgisportal/\content\items\portal.</Msg>
<Msg time="2018-05-24T20:53:48,493" type="INFO" code="217048" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Arrêt du moniteur de traitement en cours.</Msg>
<Msg time="2018-05-24T20:53:48,496" type="INFO" code="217049" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Arrêt du serveur Web.</Msg>
<Msg time="2018-05-24T20:53:48,497" type="INFO" code="217050" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Arrêt du serveur de base de données.</Msg>
<Msg time="2018-05-24T20:53:58,580" type="INFO" code="217051" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Tous les traitement ont été arrêtés.</Msg>
<Msg time="2018-05-24T20:53:58,580" type="INFO" code="217048" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Arrêt du moniteur de traitement en cours.</Msg>
<Msg time="2018-05-24T20:53:58,582" type="INFO" code="217049" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Arrêt du serveur Web.</Msg>
<Msg time="2018-05-24T20:53:58,583" type="INFO" code="217050" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Arrêt du serveur de base de données.</Msg>
<Msg time="2018-05-24T20:53:58,637" type="INFO" code="217066" source="Portal" process="8744" thread="1" methodName="" machine="DATA.APAL.LOCAL" user="" elapsed="">Arrêt du thread du chien de garde.</Msg>
