Portal content missing services
1546
07-16-2018 01:17 PM
DianeBird
I am running Portal 10.6 with a federated, hosting server (Arcgis Server 10.6). The portal has anonymous access and the publishing webadaptor has basic authentication. When I publish a new service, it does not appear in my "Contents" section on the portal, and the web application wants an additional login, which returns an Error #2048 dropping the service from the application. What do I need to change to enable all services and avoid this error?
BillFox
MVP Frequent Contributor
Hi Diane,
Try setting Anonymous on the web adapters for Portal and ArcGIS Server.
-Bill
DianeBird
I found the problem.... even though I published the service, it was listed under the other administrator's content and not yet shared.  Once I gave it permission to share to the organization, it came up in the application with no additional login request.
Thanks.
