North of 62° (EPSG 1612)
1464
05-10-2012 04:27 AM
FugroSurvey_Ltd_
I've been given a few CAD layers and projection details are:
Projection: Universal Transverce Mercator
CM:9°E
SPHEROID: International
DATUM: ED50, North of 62° (EPSG 1612)
So my question is when Defining projection in ArcMap what Projected Coorinate System should I select?
Thank you
MelitaKennedy
Esri Notable Contributor
The EPSG 1612 reference on the datum is for a geographic/datum transformation, ED 50 to WGS 1984 (23). The software this data comes from must be "early-binding." That is, each GCS/datum has a transformation linked to it. ArcGIS is "late-binding." Data is tagged with a neutral coordinate system definition. When you need to transform it to another coordinate systems, then you pick a particular transformation. So define the data with ED 1950 UTM zone 32N (north). If you need to convert it to WGS84, use ED_1950_To_WGS_1985_23.
Melita
FugroSurvey_Ltd_
Hi Melita,
Thank you very much for you reply. That makes sense and I will do it.
Thank you
Patricia
