List services in Portal for ArcGIS
12264
11
03-22-2021 08:59 PM
Labels (2)
Dionisiobattad
I am trying to create a list of all services that we have in our Portal. I have seen this script in ArxcGIS Server Administration (https://enterprise.arcgis.com/en/server/latest/administer/windows/example-write-properties-of-all-se...).
When I run it using our server name, port, and my credentials as administrator, I get this error message:
gaierror: [Errno 11001] getaddrinfo failed
I am using IDLE but do I need to use Python 3 here? We are still using 10.6. Thanks.
arahman_mdmajid
Thanks to @LongDinh I was able to reimplement the script using requests module. Below is the working script
# Reads the following properties from services and writes them to a comma-delimited file:
#  ServiceName, Folder, Type, Status, Min Instances, Max Instances, KML,
#  WMS, Max Records, Cluster, Cache Directory, Jobs Directory, Output Directory
# encoding=utf8
import sys
reload(sys)
sys.setdefaultencoding('utf8')
# For HTTP calls
import httplib, urllib, json, requests
# For system tools
import sys
# For reading passwords without echoing
import getpass
def main(argv=None):
    # Ask for admin/publisher user name and password
    username = raw_input("Enter user name: ")
    password = getpass.getpass("Enter password: ")
    # Ask for server name & port
    serverName = raw_input("Enter server name: ")
    serverPort = 6443
    # Get the location and the name of the file to be created
    resultFile = raw_input("Output File: ")
    # Get a token
    token = getToken(username, password, serverName, serverPort)
    # Get the root info
    serverURL = serverName + ":"+ str(serverPort) + "/arcgis/admin/services/"
    # This request only needs the token and the response formatting parameter
    params = {'token': token, 'f': 'json'}
    # Connect to URL and post parameters
    response = requests.post(serverURL, data=params)
    # Read response
    if (response.status_code != 200):
        print "Could not read folder information."
        return
    else:
        # Deserialize response into Python object
        dataObj = json.loads(response.text)
        #Store the Folders in a list to loop on
        folders = dataObj["folders"]
        #Remove the System and Utilities folders
        folders.remove("System")
        #folders.remove("Utilities")
        #Add an entry for the root folder
        folders.append("")
        #Create the summary file of services
        serviceResultFile = open(resultFile,'w')
        serviceResultFile.write("ServiceName,Folder,Type,Status,Min Instances,Max Instances,FeatureService,kml,wms,Max Records,Cluster,Cache Directory,Jobs Directory,Output Directory" + "\n")
        #Loop on the found folders and discover the services and write the service information
        for folder in folders:
            # Determine if the loop is working on the root folder or not
            if folder != "":
                folder += "/"
            # Build the URL for the current folder
            folderURL = serverName + ":"+ str(serverPort) +"/arcgis/admin/services/" + folder
            response = requests.post(folderURL, data=params)
            # Read response
                return
            else:
                # Loop through each service in the folder
                for item in dataObj['services']:
                    if item["type"] == "GeometryServer":# and folder == "":
                        # Build the Service URL
                        if folder:
                            sUrl = serverName + ":"+ str(serverPort) + "/arcgis/admin/services/%s%s.%s" %(folder,item["serviceName"], item["type"])
                            statusUrl = serverName + ":"+ str(serverPort) + "/arcgis/admin/services/%s%s.%s/status" %(folder,item["serviceName"], item["type"])
                        else:
                            sUrl = serverName + ":"+ str(serverPort) + "/arcgis/admin/services/%s.%s" %(item["serviceName"], item["type"])
                            statusUrl = serverName + ":"+ str(serverPort) + "/arcgis/admin/services/%s.%s/status" %(item["serviceName"], item["type"])
                        servResponse = requests.post(sUrl, data=params)
                        # Get the response
                        jsonOBJ = json.loads(servResponse.text)
                        # Build the Service URL to test the running status
                        # Submit the request to the server
                        servStatusResponse = requests.post(statusUrl, data=params)
                        # Obtain the data from the response
                        jsonOBJStatus = json.loads(servStatusResponse.text)
                        # Build the line to write to the output file
                        ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["clusterName"]) + "," + "NA" + "," + "NA" + "," + "NA" +"\n"
                        # Write the results to the file
                        serviceResultFile.write(ln)
                    elif item["type"] == "SearchServer":# and folder == "":
                        if folder:
                        else:
                        # Get the response
                        # Get the response
                        ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["clusterName"]) + "," + "NA" + "," + str(jsonOBJ["properties"]["jobsDirectory"]) + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
                    elif item["type"] == "ImageServer":
                        if folder:
                        else:
                        # Get the response
                        if folder:
                        else:
                        # Get the response
                        # Extract the WMS properties from the response
                        wmsProps = [imageWMS for imageWMS in jsonOBJ["extensions"] if imageWMS["typeName"] == 'WMSServer']#.items()[0][1] == 'WMSServer']
                        if len(wmsProps) > 0:
                            wmsStatus = str(wmsProps[0]["enabled"])
                        else:
                            wmsStatus = "NA"
                        ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + wmsStatus +"," + "NA" + "," + str(jsonOBJ["clusterName"]) + "," + str(jsonOBJ["properties"]["cacheDir"]) + "," + "NA," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
                    elif item["type"] == "GlobeServer":
                        if folder:
                        else:
                        # Get the response
                        #Build the Service URL to test the running status
                        if folder:
                        else:
                        # Get the response
                        ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["properties"]["maxRecordCount"]) + "," + str(jsonOBJ["clusterName"]) + "," + str(jsonOBJ["properties"]["cacheDir"]) + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
                    elif item["type"] == "GPServer":
                        if folder:
                        else:
                        # Get the response
                        if folder:
                        else:
                        # Get the response
                    elif item["type"] == "GeocodeServer":
                        if folder:
                        else:
                        # Get the response
                        if folder:
                        else:
                        # Get the response
                        ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["clusterName"]) + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
                    elif item["type"] == "GeoDataServer":
                        if folder:
                        else:
                        # Get the response
                        if folder:
                        else:
                        # Get the response
                        ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["properties"]["maxRecordCount"]) + "," + str(jsonOBJ["clusterName"]) + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
                    elif item["type"] == "MapServer":
                        if folder:
                        else:
                        # Get the response
                        if folder:
                        else:
                        # Get the response
                        # Check for Map Cache
                        isCached = jsonOBJ["properties"]["isCached"]
                        if isCached == "true":
                            cacheDir = str(jsonOBJ["properties"]["cacheDir"])
                        else:
                            cacheDir = jsonOBJ["properties"]["isCached"]
                        if len(jsonOBJ["extensions"]) == 0:
                            ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "FeatServHolder" + "," + "Disabled" + "," + "Disabled" +"," + str(jsonOBJ["properties"]["maxRecordCount"]) + "," + str(jsonOBJ["clusterName"]) + "," + cacheDir + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
                        else:
                            # Extract the KML properties from the response
                            kmlProps = [mapKML for mapKML in jsonOBJ["extensions"] if mapKML["typeName"] == 'KmlServer']#.items()[0][1] == 'KmlServer']
                            wmsProps = [mapWMS for mapWMS in jsonOBJ["extensions"] if mapWMS["typeName"] == 'WMSServer']#.items()[0][1] == 'WMSServer']
                            # Extract the FeatureService properties from the response
                            featServProps = [featServ for featServ in jsonOBJ["extensions"] if featServ["typeName"] == 'FeatureServer']#.items()[0][1] == 'FeatureServer']
                            if len(featServProps) > 0:
                                featureStatus = str(featServProps[0]["enabled"])
                            else:
                                featureStatus = "NA"
                            if len(kmlProps) > 0:
                                kmlStatus = str(kmlProps[0]["enabled"])
                            else:
                                kmlStatus = "NA"
                            else:
                                wmsStatus = "NA"
                            ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + featureStatus + "," + kmlStatus + "," + wmsStatus +"," + str(jsonOBJ["properties"]["maxRecordCount"]) + "," + str(jsonOBJ["clusterName"]) + "," + cacheDir + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
                    else:
                        print("All layers traversed")
        # Close the file
        serviceResultFile.close()
def getToken(username, password, serverName, serverPort):
    # Token URL is typically http://server[:port]/arcgis/admin/generateToken
    tokenURL = "/arcgis/admin/generateToken"
    params = {'username': username, 'password': password, 'client': 'requestip', 'f': 'json'}
    url = serverName + ":"+ str(serverPort) + tokenURL
    # Post parameters to url
    response = requests.post(url, data=params)
    # Read response
        print "Error while fetching tokens from admin URL. Please check the URL and try again."
        return
    else:
        # Extract the token from it
        token = response.json()
        return token['token']
if __name__ == "__main__":
    sys.exit(main(sys.argv[1:]))
Hope it helps
Note: For those like me who didn't knew how to run the script in Windows environment. Just run you Command Prompt as an Administrator and navigate to your Python installation folder, for me it was "C:\Python27\ArcGIS10.6", and run the command as "python.exe "<your-saved-directory>\service_csv.py"
Abdur Rahman
GIS Developer
LongDinh
Great work @arahman_mdmajid !
One last tip from me. When you see yourself copying and pasting code blocks you should consider refactoring the code block so that its logic can be reused. This also improves readability as the logic can be named appropriately based on its purpose (i.e. function)
A good example to refactor could be create a function to return your sURL and statusUrl variables. Both variables have 3 inputs (i.e. folder, item["serviceName"], item["type"]) and return a constructed url. E.g:
def constructUrl(serviceName, serviceType,folder=None):
  """Construct a url for this program"""
  if folder:
    url = "https://....'
  else:
  return url
Best of luck with future programs!
