Label script cutting off last character?
2496
03-07-2012 07:26 AM
ShannonPankow
Ok, so I don't know that much about vbScripts, but I am using this one to make the text on the label concatenate to fields into the label, wrap the text at a certain number of characters and insert a new line.
Function FindLabel ( [NAME], [PARKING_SP] )
FindLabel = " [NAME]  & [PARKING_SP] "
Dim finalLabel, strInput, curChar, PWS, CWS
Dim c, numChars, senLimit, numSpaces, spaceIter, CWSLen
strInput =  [NAME]  & vbNewLine &  [PARKING_SP]  '* label field names NAME & PARKING_SP
intInput = [PARKING_SP]
senLimit = 15 '*sentence limit is 15
  finalLabel = ""
  strLabel = ""
  intLabel = ""
  numChars = Len(strInput)
'Determine number of spaces in string
    numSpaces = 0
    c = 0
  Do Until (c = numChars)
      c = c + 1
      curChar = Mid(strInput, c, 1)
      If (curChar = " ") Then
         numSpaces = numSpaces + 1
      End If
    Loop
   c=0
   Do Until (spaceIter = numSpaces + 1)
        Do Until (curChar = " ") Or ((c + 1) > numChars)
          c = c + 1
          CWS = CWS + curChar
        Loop
        CWSLen = Len(CWS)
        If (CWSLen > senLimit) Then
             PWS = Left(CWS, (CWSLen - 1))
             PWSLen = Len(PWS)
             If (Len(PWS) > senLimit) Then
                 Do Until (Right(PWS, 1) = " ")
                     PWS = Left(PWS, PWSLen)
                     PWSLen = PWSLen - 1
                     c = c - 1
                 Loop
             End If
             curChar = "dummy"
             PWS = Trim(PWS)
             If (finalLabel <> "") Then
                finalLabel = finalLabel & vbNewLine & PWS
             Else
                finalLabel = PWS
             End If
             CWS = ""
             spaceIter = spaceIter - 1
        Else
           If ((c + 1) <= numChars) Then
                curChar = "dummy"
           End If
           spaceIter = spaceIter + 1
        End If
   Loop
    finalLabel = finalLabel & vbNewLine & CWS
  Else
     finalLabel = cws
End If
FindLabel = finalLabel
End Function
The problem is that it is cutting off the final character in the last line that is pulling in the number of parking spaces, but only on
*some* of the labels, not all of them....help!
MarkBoucher
Honored Contributor
I've had this same problem and am very interested in the solution.
MarkBoucher
Honored Contributor
Any help on this out there?
by Anonymous User
Not applicable
I took a stab at this...Very tricky! (or maybe I am just over thinking?) I was able to generate the labels properly using Python and printing out the labels using a search cursor, but I was unable to get this to work as a label expression. It is also very clunky. Hopefully someone who is more experienced with writing label expressions can get this to work.
def FindLabel(field,length):
    wlist = field.split(" ")
    linelist = []
    scratch = []
    chars = ""
    for w in wlist:
        if len(chars) <= length:
            chars += " ".join(["",w])
            chars = chars.lstrip()
            if len(chars) > length:
                linelist.append(" ".join(i for i in chars.split(" ")[:-1]))
                chars = chars.split(" ")[-1]
                if len(chars) < length:
                    pass
                elif len(chars) == length:
                    linelist.append(chars)
                else:
            else:
                scratch.append(chars)
    try:
        if scratch[-1] not in linelist:
            linelist.append(scratch[-1])
        if wlist[-1] not in linelist:
            linelist.append(wlist[-1])
        if linelist[-2].split(" ")[-1] == linelist[-1]:
            del linelist[-1]
    except:
        pass
    label = "\n".join(str(i) for i in linelist)
    return label
if __name__ == '__main__':  # Cut this out of label expression
    import arcpy
    dbf = r'C:\Testing\deed.dbf'
    with arcpy.da.SearchCursor(dbf,['DEEDHOLDER']) as rows:
        for row in rows:
            name = row[0]
            label = FindLabel(name,15)
            print label
            if label.replace("\n"," ") == name:
                print '\ntrue\n'
            else:
                print '\nfalse\n'
I was able to successfully get this to wrap texts when printing out to the interactive python window, but getting this to work as a label expression is a whole new ball game. I tested many different lengths (10, 15, 20, 25, 30) and it properly wrapped the text. I also did a test to make sure that all the values in the field match up after generating the labels and they all returned true.
[ATTACH=CONFIG]22963[/ATTACH]
