Is the Arcade $userInput profile variable available in Portal
1663
01-02-2025 02:00 PM
ZenMasterZeke
I created a map in AGOL that included some arcade expressions for popups. They use the $userInput profile variable in order to determine where a user clicked on the map. Works fine.
I'm trying to recreate the map in Portal, but no $userInput profile is available. I don't see anywhere in the documentation that mentions this limitation. Am I out of luck?
KenBuja
MVP Esteemed Contributor
Which version of Portal are you using? $userInput was available as of Arcade version 1.26 and according to the Version matrix, only ArcGIS Enterprise portal 11.4 supports that version.
KenBuja
ZenMasterZeke
Ah, thanks @KenBuja . We just upgraded to 11.3. The 11.4 version is probably a year away for us. Oh well.
