Is it possible to expand the domain values ​​in a smart form based on a chosen field?
611
09-26-2024 05:20 AM
HansvanBuggenum
Suppose we have a field with 3 options. A, B and C. A field with the options 1,2,3,4.
If A is selected in the first field, the second field must only show options 1 and 2, if B is selected, 1 and 3 must be shown in the second field, etc.
Can this be set in a smart form? (ArcGis Portal 11.1)
EmilyGeo
Hi @HansvanBuggenum
You can do this by setting up subtypes in ArcGIS Pro. You can designate a subtype field that will categorize features into different subtypes. Then you can customize domains as well as default values for each subtype. Those will be honored in the smart form.
HansvanBuggenum
That doesn't seem like an option. It looks like I have to create a new field first and then I can create a subtype for that filed. I can not create a subtype on existing fields. It concerns an existing feature class with a lot of data.
