Custom error message when editing features in Map Viewer
737
09-27-2024 03:41 AM
AGP
ArcGIS Enterprise 11.3 here. Working with database registered fature layers with editor tracking enabled and not versioned.
I have a number of required fields which do not allow null values. I use calculated expressions to populate them and I'd like to show a custom message when the expression leaves them empty on porpuse (for example when a user draws a feature in a restricted area).
Is there any way I can do that with Arcade in the edit form or somewhere else?
