Is it possible to edit Related table records in ArcGIS for Portal Desktop map viewer?
5261
11
10-07-2015 06:00 AM
MatthewMurray1
I have a related table in a ArcGIS for Portal web map. I have a web map that I have configured with a feature service that has a related table. The feature service has all the editing capabilities and I can successfully add, and edit records. What I can't do is seem to figure out is how to edit or add feature in the related table. This following blog post describes how it can be done using ArcGIS Collector but i cannot find anything for a standard web map http://blogs.esri.com/esri/arcgis/2015/02/18/related-tables-exploring-new-ways-to-use-collector-for-...
DerekLaw
Esri Esteemed Contributor
Hi Ana,
Both the link to the enhancement request and the login link to vote for the idea are working for me.
Have you tried to perhaps clear your web browser cache then reload the page?
Hope this helps,
KamillePreto
Hi Derek,
Is this still not a function in a Web Map - to edit a Related Table?
If not, how do you recommend that I edit my data in a Related Table for data displayed in a Web Map & Dashboard? I had a ticket in with ESRI support a few months ago regarding a glitch with my Dashboard and they recommended that I do all of my edits in Portal directly, rather than syncing the Web Map into Pro (which is the workflow I was doing to modify the data).
