I am using a federated portal on arcgis server and I am using feature services to capture data in the field, the version I am usng is nt reconciling to my gdb, I have to download the feature service and manually add the features everyday to the gdb, what
1104
01-20-2017 02:22 PM
AmyStorey
I am using a federated portal on arcgis server and I am using feature services to capture data in the field, the version I am usng is not reconciling to my gdb, I have to download the feature service and manually add the features everyday to the gdb, what am I missing?  Also I cannot figure out how to view any conflicts when i reconcile.
DerekLaw
Esri Esteemed Contributor
Hi Amy,
> ... the version I am using is not reconciling to my gdb ... Also I cannot figure out how to view any conflicts when i reconcile
Can you please describe your workflow in more detail? For example, after you've captured data in the field (how and with which app?), do you open the feature service (used by the field app) in ArcMap and attempt to perform a reconcile operation? When you perform a reconcile, conflicts should appear.
Reconciling a version—ArcGIS Help | ArcGIS Desktop
Hope this helps,
