I donn't want to visible organization tab and organization content along with other user details to Level 1 user.
so please suggest how to disable Organization Tab for Level 1 user.
Attached Portal level 1 user login organization page. Want to disable red box content .
Create a custom role where users don't have the privilege to view members
-Kelly
I there any way to disable Organization tab from Portal for ArcGIS page after login with level 1 role.
Is there any way to disable Organization tab from Portal for ArcGIS page after login with level 1 role
-Kelly
Can a user be part of more than one role?
Thanks your for Reply.
Great workaround .
Hi Kelly @KellyGerrow , I tried the same way which was mentioned in the above link. but im still facing the same issue. my external user is able to see our organization content. even though i have unchecked view content shared with organization while creating custom role. Please suggest on this. we are using arcgis enterprise 10.8.1.
Note: we have exposed our portal to public and created basic viewer custom role.
A user can be assigned to one role, but each role can have different privileges. It is recommended that you include all of the needed privileges for a user in the role that you create.
-Kelly
