How to add a WMS service into HTTPS-only/Win-Authenticated Portal
4788
06-01-2015 11:04 AM
SteveStearns
  We have an enterprise Portal which is HTTPS-only and uses windows-authentication.  We have a CAD client that wants to use a series of OGC (WMS and WFS) layers registered in the Portal.  Attempting to add the layers in the client (or in ArcMap) gives an error that a token is needed.  By generating a token on the portal administration page, you can add the WMS service into ArcMap or into the CAD one time, but a subsequent attempt to add (even for a two-week token) will fail.  What is wrong here?  The URL I use in ArcMap is like https://mysite.domain.com/portal/..../WMSurl?&token=xxxxxx  .  It will work exactly once in ArcMap (ditto for the CAD client).  It fails the next time I try to reconnect, no matter how soon.
Tags (4)
DavidMann1
I have a similar situation.  Did you ever figure out a solution?
SteveStearns
We never figured this out.  The Portal machine was upgraded to 10.3.1 and we configured it to support both HTTP and HTTPS.
