Time slider on web map do not update starting date and end date.
1815
02-18-2016 12:59 PM
Mauricio_Arroqui
Hello
I have an issue with a time layer that add to a map in a portal context. The data represent the last 24hs of objects moving, after 24hs old objects are removed from database. I configure the time slider in arcmap, and when the day changes the time slider starting date changes, but on the map in portal the starting date does not change automatically as in arcmap.
Someone can helpme with this issue? Is this a bug?
Thanks in advance!
Mauricio.
