How do Enterprise Geodatabases, Enterprise Portal and ArcGIS Online work together?
1493
08-21-2024 08:41 AM
MatthewStull1
I am considering implementing the Enterprise Portal and I am wondering how it works with Enterprise geodatabases?  The ESRI help documentation isn't giving me the detail I'm looking for.  I want to have a copy of many of my layers in ArcGIS Online so that my map viewer apps can use the layers from there instead of using ArcGIS Server.  My main questions and concerns are:
- Will I have to move my data into some other database/data store that Portal uses, and will I only be able to see and interact with it through the Portal AGOL-like interface?  OR will I be able to keep my Enterprise Geodatabase just like it is and have Portal simply access it?  OR does it work some other way?
- Second, how does the syncing of feature layers/tables between Portal and ArcGIS Online work?  I have Safe Software's FME and I could simply setup a workspace job to sync layers/data between my Enterprise Geodatabase and ArcGIS Online without using Portal.  Why would I want to use Portal instead of FME?  Is it easier/better to do the syncing of layers via whatever tool Portal uses?
That's it, thanks for your feedback!
MarceloMarques
@MatthewStull1
ArcGIS Online you can upload a File Geodatabase as you know.
https://doc.arcgis.com/en/arcgis-online/reference/supported-items.htm#:~:text=File-,geodatabase,-(.z...
You can use ArcGIS Online with a Feature Service or Geodata Service, this means the external ArcGIS Server Service can be fetching the data from an Enterprise Geodatabase. The ArcGIS Server Service can be running on your data center or in the Cloud.
Please, read this blog for more information about how to integrate data with ArcGIS Online.
Seven Ways to Integrate Data with ArcGIS Online (esri.com)
ETL for ArcGIS Online using Data Interoperability
Using Data Interoperability to sync data to ArcGIS Online - Esri Community
This shall point you in the right direction.
I hope this helps.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
berniejconnors
Matt,
        I see you work for a city government.  Does your question refer to open data or does this data need to be secure?  I am in a similar situation - I work for a provincial government in Canada.  We publish many map services.  All of our map services are public (https://geonb.snb.ca/arcgis/rest/services).  We only use ArcGIS Server.  We have not deployed Enterprise / Portal.  We use ArcGIS Online to create and publish map viewers that directly consume our map services.  We do not have a need to duplicate our datasets in AGOL.  Your situation may be different.  But our situation does not require our data to be duplicated in AGOL.
Cheers,
Bernie.
MatthewStull1
Bernie,
Our current setup is similar to the one you described.  We also use GeoCortex/VertiGIS.  The reason I'm looking at AGOL and or Portal is that I see it as a much better and more flexible solution (not to mention we're paying ESRI a lot of money to use these systems and I want to make better use of them).   Here is a list of advantages that I see to using AGOL and or Portal over just an ArcGIS Server:
Flexibility – easy to share data to anyone anywhere
Feature Layers or hosted tables are easy to share for integration into other enterprise-like systems like Cityworks, IT Pipes, Accela or others.
Easy to do metadata / documentation
Easy to setup and manage permissions, licenses, groups, and users
Easy setup for mobile data use and updates
Easy to create maps and apps for whatever use.
Easy to make your data and maps available for use on various devices like website, smartphones, tablets, ArcGIS Pro
Easy to see stats and other information like:  when was the layer created, when was the layer last updated, how many views as it gotten
Editor tracking will show the actual username of who edited the data, rather than “ESRI Anonymous”.
Availability will be very high – better than our local ArcGIS Server
Don’t have to worry about internal software upgrades to Windows or ArcGIS Server that could affect the data availability.
The apps and maps should work faster.
Makes us less dependent on our Network team.  In other words, we have more control of our stuff.
