Geoform requires editable feature in Portal, but my hosted feature is editable?
1242
11-02-2018 08:11 AM
JasonCarter1
I'm attempting to make a Geoform to edit a feature service in Portal for ArcGIS. I am receiving the error here:
However, my layer is set to be editable. What could be causing this issue? Am I missing something about how to set up the hosted feature?
Screenshot of the features settings:
Thanks in advance..
Tags (3)
BruceAnderson1
I'd try unchecking the Enable Sync option and see it that makes a difference.
JasonCarter1
Thanks for the reply. That didn't seem to work. I am still not able to select a layer. I modified the editing capabilities in Portal after publishing the service from ArcMap. Do you think I need to publish it as editable rather than changing the permissions after the publishing? I'll go ahead and give that a try..
Thank you
JasonCarter1
After further research it appears that polygon features are not usable in the GeoForm... is that correct?
