Esri Maps for SharePoint: Invalid redirect_uri
2901
10
04-11-2017 09:56 PM
BudurR
Hello,
I have installed Esri Maps for SharePoint and configured every thing. It was working before 2 weeks.
Now when I enter the page it ask me to login (Click here to sign in to ArcGIS.) and then I got following error:
Error
Error: 400
How to slove this? I need your help please.
Attached (Configuration Settings) page
BudurR
Any help please
DerekLaw
Esri Esteemed Contributor
Hi Budur,
Perhaps this FAQ doc might enable you to troubleshoot your issue,
Frequently asked questions—Esri Maps for SharePoint | ArcGIS
Hope this helps,
BudurR
I didn't find any solution there
JonathanQuinn
Esri Notable Contributor
Are you able to reach the Portal home page and sign in without any problems?
TaraEvoy
I have this exact same issue!
Has anyone found a resolution to this? Pleas help!
JonathanQuinn
If you go to /portaladmin/security/oauth/getAppInfo and then enter mapsForSharePoint in the App ID parameter, what output do you get?  FYI this will include hostnames so take that into consideration before posting the output.  If the public Portal URL isn't in the list of redirect URI's, that may be the problem.
TaraEvoy
I get an ArcGIS page that says "We're sorry, the page you're looking for can't be found."
I should mention that I am using my AGOL subscription for my maps for sharepoint, I do not have Portal for ArcGIS installed locally. It was working perfectly since I configured it months ago until a couple weeks ago.
TaraEvoy
Any ideas? Still an issue for me, I have tried multiple attempts to fix this, cannot determine why I am getting this.
Budur R did you ever resolve this for yourself?
DerekLaw
Hi Tara,
Both JQuinn-esristaff‌ and I are more familiar with Portal for ArcGIS, than ArcGIS Online. I shared this thread to the ArcGIS Maps for Office forum, hoping others might be able to assist.
I suggest you contact Esri Tech Support to open an incident as they can best help investigate your issue.
Hope this helps,
