Error running Portal analysis tools
810
03-18-2017 01:13 AM
ИванМехедов
When I'm trying to run any analysis tool in Portal, I always get a message dialog "Error" with no any error description.
If I run Buffer tool, I see the following message in Server logs:
Server log message
And I see the following message in Portal logs:
Portal log messages
At the same time, publishing hosted services from ArcGIS for Desktop to Portal works correctly.
ArcGIS for Server Advanced is federated with Portal and is used as hosting server, Data Store is intalled.
Platform version 10.4.1.
