Error Adding Secure Services (Storing Credentials) 10.3
6453
10-14-2015 07:44 AM
ThomasSchultz
Whenever I tried to add a secure service to Portal for ArcGIS as a new item, I get an error message.  The message will vary depending on what type of service it is, but for ESRI's routing service, for example, I get "Error Generating Token".  I've also tried to create a helper service proxy item according to the instructions:  Add premium helper services—Portal for ArcGIS (10.3 and 10.3.1) | ArcGIS for Server, but this yields the same result.  All of the services I am trying to add can be added to ArcGIS Desktop without problem, so I've been focusing on the forward proxy settings for Portal.  I have configured Portal for our forward proxy according to the instructions I could find, but I am not sure if it is working.  I have a support ticket open with ESRI, but I am wondering if anyone else has successfully overcome this kind of issue.
ThomasSchultz
After upgrading to Portal for ArcGIS 10.4, this problem has gone away.  I think the solution involved two things.  First, our forward proxy does cause issues when trying to store credentials.  I never go the proxy config settings to work correctly, but for now, whitelisting the sites has solved that problem.  Second, even this only worked after upgrading to 10.4, so I have to assume that there was a bug in version 10.3 causing a problem.
VHolubec
Dear Thomas,
have you found with Esri support some solution?
Thank you for reply.
Vladimir
Vladimir
ThomasSchultz
I am actually still working with ESRI on this issue.  Still assuming it is being caused by our forward proxy, but have not found a solution either with ESRI or our Security group in IT.
ThomasSchultz
MichaelKelly
You may also need to add your server certs to portal so they are trusted:
Configuring the portal to trust certificates from your certifying authority—Portal for ArcGIS (10.4....
Make sure you restart portal and clear your existing browser data.
